water and white smoke coming out the exhuast pipe!!!
  • crazynoll
    • Feb 2007
    • 54
    does that just mean a blowin head gasket or can it be something else.
    the car still runs fine i only notice the smoke and water when i first start it up and give it alittle gas.can anyone help?
    o yah and i did a oil change about a month and a half ago and didnt notice any water in the oil. and i also tried that engine restore stuff like 2weeks ago, did i mess up by using that stuff.
    <img src=http://www.r3vlimited.com/board/image.php?u=14143&dateline=1175417424&type=profile >
  • KangamangusDriver
    • Aug 2005
    • 1870
    Usually when a head gasket goes you will have continous white smoke/steam come out your exhaust.
    This will occur at all times, engine hot/cold.
    Coolant leaks into the combustion chamber, creates steam and exits out the exhaust. Assuming the leak is continous, this will create steam at all times.
    Check your coolant level, check the color.
    -Does it appear low?
    -Does it look like a choclate shake?
    If it looks like a choclate shake it means you have oil in your coolant. Not fun!
    • AndrewBird
      The Mad Scientist
      • 11897
      The head gasket could be blown just enough to leak coolant into the combustion chamber(s). Just because you don't have oil in the coolant or coolant in the oil doesn't mean you don't have a blown head gasket.
      I would check the level. If it's low, fill it up and check it in a day or two after you've driven.
      • Axxe
        • Aug 2004
        • 3355
        All cars smoke white when they are cold!! This is water vapor condensing because the motor isn't hot enough to fully evaporate it.
        Keep it slideways!!
        • Court M3
          • Jan 2004
          • 6713
          my car is doing the same thing. Going to check the head gasket next week. Hopefully isn't that.
          Continuous For Sale Thread
          323i s50
          • crazynoll
            • Feb 2007
            • 54
            yah its mostly when its cold, but what does it mean when u take off the oil cap when its running and the car wants to die.
            • delphini
              • Apr 2006
              • 680
              By removing the oilcap you are essentially creating a huge vacuum leak. Keep a CLOSE eye on this issue and try not to drive it IF it is a headgasket. This could lead to other problems , such as a warped head, and this =much more money.
              :pimp:
              • crazynoll
                • Feb 2007
                • 54
                well i havent been losing much water only a little every month or so and the color hasnt change the smoke only happend when i first start the engine when its cool but goes away after it warms up.
                  There is a noticably different appearance of vaporized coolant and normal condensation. once you've seen vaporized coolant coming from the exhaust as a result of a blown head gasket you'll never mistake one for the other. If you aren't sure whether this is coolant or condensation, have an experienced tech take a look.They'll know instantly which it is.
                  • HST
                    • Jan 2006
                    • 757
                    coolant smoke should smell kinda sweet.
                    Originally posted by KingB
                    Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                    • AlarmedBread
                      • Sep 2006
                      • 1510
                      You would be able to tell the smell is different and sweet. Below is an example of the 'milk shake' After the car has warmed up it will look like this, if you pull the oil cap and see this, stop driving the car immediately.
                      Take a whiff of your exhaust and get back to us.
                      • strad
                        • Jan 2007
                        • 241
                        Yes: and the reason the water is there in the first place is that it is a hydrocarbon combustion reaction byproduct. In other words, it's ALWAYS there, cold or hot. It's also the cause of exhaust systems rusting from the inside out rather than the reverse.
                        The current fleet:
                        1992 325ic: 148k-171k miles
                        1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
                        1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
                        • StereoInstaller1
                          GAS
                          • 22679
                          Metric Mechanic talks of a crack that happens in the lifter valley between cylinders #4 and #5, allowing coolant into the oil.
                          I fear that same crack in my sweeties head. Pressure testing happens today.
                          Luke
                          Closing SOON!
                          Thanks for 10 years of fun!
