Turn signal....
    Turn signal....
    Alright. this is whats going on now. Turning right, it clicks really fast because front turn signal is out. no duh. turn left signal on, and it goes normal, then speeds up, then stops, then it goes fast again, then it just makes a machine gun clicky noise... with no flashing on the cluster... any idea?
    turn signal relay maybe.
    Continuous For Sale Thread
    323i s50
      also check the signal stalk.
      mine is shot, so when i turn left, it always blinks fast. Like when you turn it only a little bit, it blinks faster than when you do it all the way. All lights,fuses and relays are good. just a contact in the switch is broken.
