would a 84 318 LSD fit my 91 318?
  • nickmpower
    • 82
    would the lsd from a 84 318 fit my 91 318?
  • Jordan
    • 12912
    If you are going to swap diffs, put a big case diff in from a 6 cylinder e30.
    Small case diffs are weak.
    https://mtechniqueabs.com/
    • Charlie
      kid tested, administrator approved
      • 6686
      A bigger diff is gonna make that m42 feel like a slug.
      Bigger diffs are heavier, with heavier internal components, aka more driveline loss.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • Stu Mc
        • 4083
        -Charlie
        Doubtful on the drivetrain loss, both diffs are still taking a 90-degree angle to get the power to the wheels.
        Big case, low ratio diffs definately make em feel slower. I had to rock a 3.25LS in mine for about a month one time. :down:
        • Rob
          • 8166
          and m42s dont exactly have diff busting torque...
          BEERTECH
          • Stu Mc
            • 4083
            My dad asked, "what the hell did you do to this thing" when we took my stock 4.10 apart (after blowing the fucker up).
            • Charlie
              • 6686
              -Charlie
              A bigger diff has heavier internal components, meaning more rotational mass, therefore meaning more driveline loss.
              -Charlie
              FYYFF
              • nickmpower
                • 82
                well i found a 84 318 lsd for like $135 so i think im gunna get it. It would fit right?
                • nickmpower
                  • 82
                  • Jordan
                    • 12912
                    Yes it will fit, no its not the correct ratio.
                    You want a 4.10:1 LSD and nothing else.
                    • nickmpower
                      • 82
                      its a 3.91 so its not that far off
                      • Jordan
                        • 12912
                        Thats off by alot. 318i's are slow enough as is. No need to change the gearing and make it even slower.
                        • e30Matt
                          • 5077
                          4.10LSD all the way. Mine has an E30 M3 diff, I'd definitely recommend it for a one-eight.
                          • nickmpower
                            • 82
                            could i just swap the lsd unit from one diff from the other?
                            my moms 735 has a 4.44 i believe lsd but i love to drift in that too much
                            • Jordan
                              • 12912
                              I would have to say no, just because you asked. Tearing apart a LSD diff is not something you shoudl do unless you know what you are doing.
