89 to 87 wiring harness
  • Super-Eta
    • 53
    somone said this it brought up a good question.
    Mitch M wrote:
    What year harness. 87 "i" harnesses are bolt in for ETA cars. 88 up take work.
    so that brings me to this can i swap in an 87 harness for my 1989 325i engine?
    How much are harness's?
    i have a 1986 325eS.
  • Jordan
    • 12911
    all etas use a different engine harness then i cars.
    the 87 i harness is different then the 88+ one
    a i harness with not work with a eta. the vehicle will not start.
    https://mtechniqueabs.com/
    • AndrewBird
      The Mad Scientist
      • 11898
      Yes, we know that from experiance. lol
      Andrew
      • Super-Eta
        • 53
        So then what should i do to get the car started?
        So basically your saying the 87 harness is more compatiable with the Eta then an 88+ harness but still doesnt mean it is 100% compatiable. correct
        • rs4pro3
          • 5808
          You can make it work but it requires some wiring to convert from one style plug to the other.
          85 325e 2.7 ITB'd stroker
          • Super Eta
            • 1884
            Does any one know where i get get the instructions or whatever on how to wire the plugs correctly?
            • Jordan
              • 12911
              the entire C-101 connector needs to be rewired... its not worth the damn trouble. This is one of the major reasons why no one does I swaps into Etas.
              Buy a Bentley manual, the scematics you need are in there.
              • rs4pro3
                • 5808
                Here is a link to the wiring http://pws.prserv.net/usinet.wdroll/c101-1.htm
                • James Crivellone
                  Head Janitor
                  • 6301
                  Then I guess swapping my M20B25 into my ETA aint worth my time :p
                  just looking over the schematics, it does not seem THAT hard, just following and tracing wires to different places.
                  Plus I don't like the idea of buying an I just for the motor when I already have a perfectly good chassis AND an m20b25 on my engine stand :)
                  • Super Eta
                    • 1884
                    I trust you enough to have you come over and take a peek and poke around in my car when i do this swap. 8) (i just may need your skillz anyway)
                    I also hear you can use the Eta engine harness is this true or is it for 88+ only?
                    • Kavkazia
                      • 394
                      When I put 87 m20b25 motor in my 90 325, I had to use some parts of my 90 m20b25 original motor, far as I can remember, T/B is different, looks same but has extra hole, can be blocked but I didnt wanted to waste time so I put my old one, oil check light swtich plugs are different, which can be rewired but I swapped my from my original motor, fuel rail is different, has return line from firewall, and my original motor has from front/radiator, and I think thats about it, far as I can remember.
                      95' M3.
                      90' 325i Turboed.
                      87' 325eS Fixed.
