How can you tell which one is worn? When I hit bumps, the front rattles. Feels like it's down low where the control arm is. The car has been on H&R race/Bilstein sports for a year and 2 months ago I replaced the CABs with M3 ones.
Strut mounts vs. ball joints. How to tell?
Tags: None
As soon as you get the ft wheels of the ground you can tell if its the balljoints by grabbing a wheel and moving it around .
You can also look at them with the wheel removed .
You should also be able to bounce the ft end with the hood up and look/listen closely to the upper strut mounts . -
