AIrflow meter, Air temp voltage -> degree
  • E30godz
    • 1524
    I wired up the SMT-6 to intercept the Airflowmeter air temp signal, and it gives me a nice voltage reading...when cruising it gives me about a 2.5 V signal but when i datalogged it and under full blast turbo boosting goodness, it gives me a .8 or so V reading...im trying to figure out how to work these into degree readings..anybody?
  • E30godz
    • 1524
    oh at cruising the 2.5V is (im assuming) the ambient temperature, which was about 80 degrees today.
    • skat 325is
      • 296
      My check engine light have stayed on since the first time the car received boost
      • E30godz
        • 1524
        wierd, my doesnt come on...
        maybe means a shitty A/F ratio...bad enough to make the check engine come on
        • mspiegle
          • 1026
          i think the absence of the temp sensor will keep the check-engine light on.
          Michael Spiegle
          '01 Ford Escape / Daily Driver
          '99 M3 / Track Car
          '87 325is bronzit / wtf car
          '06 Daytona Triumph 675 / Daily Rider
