I'm about to order a few hundred dollars worth of maintenance parts, have questions..
  • Joey Link
    drunkest guy at Oktoberfest!
    • Nov 2004
    • 1176
    Here's my list so far:
    Valve Cover Seal
    Valve Cover Paint
    Exhaust Stud
    Exhaust Gaskets (Manifold to Collector)
    Thermostat
    Water Pump
    Camshaft Seal & O-Ring
    Coolant Hoses
    Throttle Body Heater Gasket
    Coolant
    Timing Belt & Tensioner
    Engine Oil & Filter
    LSD Oil
    Fuel Filter
    Flex Disc
    Flex Disc Nuts
    Rear Transmission Seals
    Transmission Oil
    Center Support Bearing
    Rubber Shift Lever Gasket
    Shift Linkage Refreshment Parts (SSK?)
    UUC Delrin Bushings
    Antenna Grommet
    That should cover the engine and transmission, as well as a few other little things.
    My first question, how much do you guys think this is going to cost me for all these things?
    Second, for things like the thermostat, water pump, and other parts that have multiple manufacturers, is there one brand that's better than the others or are they all the same?
    Third, where's the best place to order from? Discount Import Parts is close and I could get the parts right away, but their prices are a little bit higher (only around 10% I'd say). The other nice thing is I could return them easily. The downside is I won't be able to select the manufacturer of the parts, if that matters, since they don't carry multiple brands of the same part.
    Fourth, while I'm doing all this is there anything I'm forgetting that I should do?
    Thanks guys.
  • erik325i
    • Jan 2005
    • 3567
    Just talk to Patrick at BMA Parts. He'll hook you up with everything you need.
    With a long list of parts like that, I'd recommend emailing him instead of calling though.
    -Erik
    • StereoInstaller1
      GAS
      • 22679
      I was headed up to PDX a couple of weeks ago. Similar list, too.
      I ordered from BMA while on the road, since every price I checked was about 15% cheaper.
      Luke
      Closing SOON!
      Thanks for 10 years of fun!
      • Joey Link
        • Nov 2004
        • 1176
        Nice Luke. Sounds like BMA it is. Anyone have an answer to the other questions? Especially #2, there's like 4 different brands of water pumps. And what thermostat temperature is better for the Northwest?
        • 87-325ic
          • Apr 2006
          • 1198
          get like an 80 degree C t-stat, better heater operation, lets the car warm up faster.
          and i only use patrick too, he is also good at reccomending brands..
          call and talk to him,
          • StereoInstaller1
            GAS
            • 22679
            What is your plan on the SSK? I just did the Z3 dealy-o and am unhappy because I half-assed it. I only did the shifter and pivot. It is still better than it was, but it eats dick IMO. PLUS the shifter is forward from where it is supposed to be, because it is straight (unlike its dick-eating linkage).
            So, UUC, AKG, OE, whoever, get the whole package, be prepared to drop whatever parts necessary to replace ALL of the parts...or don't bother.
            I wanna try the "raised cup" deal too. I hate the extreme notchiness.
            /whine
            Closing SOON!
            • dinanm3atl
              • Feb 2007
              • 7305
              Go with the Z4 2.5i shifter.
              Then get new yellow spacers, get a new shifter knuckle, replace the uuc delrin bushings, The way you do everything right the first time.
              • DJB
                • Oct 2005
                • 195
                Valve Cover Seal
                PPE-A8030-14709-ELR Valve Cover Gasket $5.76 $5.76 8.29, 8.36
                11-12-1-730-229 Valve cover gasket $6.49eap Elring
                You'll also want 4 of these:
                11-33-1-264-519 rocker shaft end plug in head, $0.90P, $0.75eap
                Valve Cover Paint
                I like my wrinkle paint, but plan on at least a full day to cure!
                Exhaust Stud
                Which ones? M8 for head-manifold, M10 for manifold-downpipe How many?
                11-76-1-711-717 Exhaust manifold flange gasket, $3.98 ($11.31)
                You'll need six new copper nuts
                18-30-1-737-774 M10 nut, copper, exhaust manifold to cat 0.40/0.34, 6@ 0.25
                or from fap99.com
                BMW012507 Exhaust downpipe gasket, 3 holes (11-76-1-711-717), Elring $3.00
                Thermostat
                Buy the BMW-sourced one for about $20
                11-53-1-466-174-80 80C Thermostat
                Water Pump
                Water pump part numbers
                Note these are pre-1988 pumps, with two inlets in casting
                '88+ pumps have a single inlet in casting
                Common brands: Geba, Lasso/Laso, GMB, Graf, Meyle, HEPU
                11-51-9-071-562 water pump, remfd, AllOEM and Pelican part number, $45.70
                eap4part Graf brand, $34.95, Lasso $40.95, BMW $47.95
                11 51 1 706 508 FAP99 (ebay) part number, not BMW #, for pre-88 pump, $31
                11-51-1-711-492 BavAuto part number, $44.95
                11-51-1-722-677 water pump gasket, $0.80
                11-12-1-265-087 O-ring 53mmx2mm behind camshaft seal, $1.50P-S
                11-12-1-285-609 Shaft seal 38x50x7, cam&intermediate shafts, $10.80
                This seal is $5-7 aftermarket
                Coolant Hoses
                Buy BMW branded hoses for the large diameters -- aftermarket hoses are not
                molded with sharp-enough turns and will rub on the fan or pulleys!
                About $1.20, at the dealer only
                Coolant
                Unlike a few years ago, you can now easily get good aftermarket coolant.
                Make certain it says "Global Lifetime" or "Global Extended Life". I use
                Peak but other major brands have specific products that work well.
                Contitech only, and buy the kit! About $25
                Also buy new plastic bits and a real BMW label:
                11-53-1-714-433 Hose support, to lifting bracket $1.59/$1.35
                11-14-1-716-134 Wiring Bracket 2@ $0.43/0.37
                01-00-1-467-809 Cambelt label, suggested retail is $0.22
                Engine Oil & Filter
                Too many opinions.
                LSD Oil
                Any GL-5, although many here like RedLine
                Transmission Oil
                Use only GL-4 for the transmission, which pretty much means RedLine MTL/MT90
                Fuel Filter
                Fuel filter, expect $9 - $14
                Flex Disc
                Flex Disc Nuts
                07-12-9-964-672 Self-locking hex nut for guibo, M10, 6@, $0.25
                Rear Transmission Seals (dealer/aftermarket prices)
                23-12-1-282-394 Shift shaft oil seal, 15x21x5, $8.60, $2.35
                23-12-1-205-340 Transmission output shaft seal, 40x55x8, $12.40 , $2.95
                23-12-1-220-619 Transmission Input Shaft Oil Seal; 35x52x7mm $7.17, about $3
                23-21-1-490-120 Safety plate/Lock plate, driveshaft output flange, $0.85/$1.33
                Socket needed 30mm (1-3/16" = 30.16) deep thin-walled socket
                Maximum diameter to fit in flange:1.57" or 40.1mm OD, 14.0mm
                Interal relief: minimum diameter of 14mm to 45mm deep
                ST Tools BMW3025 socket is 39.04mm OD, 16mm deep flats, 66mm deep
                Not the shift boot, but the rubber bellows? Boneyard part.
                Unplug reverse wires from the transmission side to feed through.
                This depends on which linkage you have. Look before buying. I have
                some extra parts because I trusted someone elses list the first time.
                UUC Delrin Bushings
                Perhaps replace sloppy parts w/ OEM before deciding that you need this
                25-11-1-220-832, Shift arm to transmission bearing sleeve 26mm, 8.00/6.80
                Superceded by 25-11-7-519-669
                Antenna Grommet
                BMW only, under $2, remove antenna motor to install
                • smonkbmw
                  Professor
                  • Jun 2006
                  • 4549
                  yeah, ask yourself "why am i spending all this money on a stock m20, when a m50 is another few hundred away?"
                  • Jand3rson
                    • 37587
                    You 24V guys all think alike. I swear, you're like Zombies. :D
                    • MikesJo
                      • Mar 2004
                      • 989
                      /whine
                      If you installed it the opposite way, it would be in the middle :). That's what my friend did for me.
                      Vancouver Portrait Photographer
                      E30 M3 Wallpapers
                      • smonkbmw
                        Professor
                        • Jun 2006
                        • 4549
                        weve all seen the light! and harnessed the POWER:hitler:!!! lmao
                        • bddog
                          • 351
                          I always buy the thermostat that stays open, as opposed to closed, when it fails.- Steve
                          • Joey Link
                            • Nov 2004
                            • 1176
                            Originally posted by DJB
                            Valve Cover Seal
                            Valve Cover Paint
                            Exhaust Stud
                            or from fap99.com
                            Thermostat
                            Water Pump
                            Coolant Hoses
                            Coolant
                            Engine Oil & Filter
                            Too many opinions.
                            LSD Oil
                            Transmission Oil
                            Fuel Filter
                            Flex Disc
                            Flex Disc Nuts
                            UUC Delrin Bushings
                            Antenna Grommet
                            Wow, thanks for taking the time to post all that. It helped :)
                            • Joey Link
                              • Nov 2004
                              • 1176
                              How much did your swap cost?
