Driveline Vibes - GRRRR
  • dinanm3atl
    • Feb 2007
    • 7305
    Ok so I have new tranny mounts coming as I know they are an issue. Also both of my rear axles have torn boots and are trashed. Keeping that in mind are they my issue?
    Flexdisc and Guibo are BRAND NEW - I have new bolts for it as I had to use 1 mismatched bolt. Not much of a miss match but not perfect
    At 65mph there is a slight driveline vibe. It goes away between 65 and 80 and comes on strong at 85 and 90. It is very fast and constant.
    It also is not as bad as before but it shudders a bit if you go hard in first and then again in 2nd at lower rpms(IE at take off from a stop sign)
    Am I on the right track here?
  • AlpineIS
    • 161
    When I replaced my guibo and center bearing a while back I also had a shudder that appeared after 55+ MPH.
    Did you preload the center bearing? I ended up having to do this and the shudder was cured.
    • dinanm3atl
      • Feb 2007
      • 7305
      Yes I did. It is pushed forward :)
      • PУCCKAЯ_e30ka
        • Jan 2006
        • 1226
        take the bolts of of the protector under car (from exhaust) and wobble the driveshaft. If its fine then it might have to do something w/ linkage (IE: somehow touches the guibo/ driveshaft) it happend on e36... don't know about manual e30ies.
        • dinanm3atl
          • Feb 2007
          • 7305
          I will be playing with it tomorrow. Realized that since I got the car I have not checked tire balance :)
          • matt
            • 3732
            That's exactly what I was going to suggest.
            • dinanm3atl
              • Feb 2007
              • 7305
              haha yah I havent checked it
              roflmao
              I am dumb :)
