ODO reset?
  • asubimmer
    • 6482
    ODO reset?
    The odo in my car went out last summer and the gas and coolant gauges act weird and jump around sometimes. So I'm thinkin about pickin up a new cluster. Is there a way that I can roll the odo all the way around to the milage of the new motor so I can keep track of it w/out math ;)
  • Mr Deagle
    • 1121
    yes, take it all apart, and reassemble it to read zero
    • ivo316
      • Oct 2006
      • 1222
      Is it too tricky to take the odo apart ?
      I am not going to do it, but is it the kind of thing that will explode in a million springs and bits when opened ? ;)
      • Febi Guibo
        • Sep 2005
        • 407
        ah charlie... if you buy yer cluster from the euro depot, they can set the odo to whatever you want...
        • asubimmer
          • 6482
          nice to know sam, thanks
          • Brew
            • 3060
            The odometer is supposed to show the mileage of the vehicle, not the engine. I don't know why this is so hard to grasp for some people. If your car gets inspected with lower mileage than the last time you got a sticker, your call will be flagged as having odometer rollback by carfax. And you can be fined or arrested. http://www.carfax.com/car_buying/odometer.cfm
            '91 318is
            • asubimmer
              • 6482
              too bad my car has already been flagged for odo changes. I know about how many miles are on the car right now. I want to know about the engine more than the body. Plus its easy to add the body milage to the engine odo readings. I have no plans on selling the car so who cares?
              • Jand3rson
                • 37587
                Not in every state. In Oregon, they don't inspect the mileage when you renew your tags. And on cars older than 9 years old, correct odometer mileage is not required.
                • bddog
                  • 351
                  Just put a new si board in yours. New plastic gears fix the odo- Steve
                  • etxxz
                    • Feb 2006
                    • 2085
                    ^^ what he said...the board is mad cheap, ebay it if you must and the gear is a pain in the lower intestinal track to change becuase everything you have to do but it gotta get done...mine is eaten up so everyhting works but the odo
                    No more e30s for me.
                    88 black BMW OBDII 332is dedicated track [sold]
                    88 BMW OBDII bronzit 332is [RIP 03/08]
                    91 BMW 325i [sold]
                    86 Corolla 'Ae86' HB 20v trd [sold]
                    http://youtube.com/watch?v=pTj7Hn9v5Rs
                    • asubimmer
                      • 6482
                      so the si board would fix the fuel and coolant? It seems like it would be easier/cheaper to get a used cluster expecially since they have come down a lot.
                      • mikeltang
                        • Feb 2006
                        • 212
                        on the back of the cluster where the fuel and temp gauges are, there should be a nut and a washer, if its loose or missing u need to tighten/replace them. im not sure exactly what it does but its supposed to keep or fuel and temp gauge working right. hope this helps.
                        AWII 1991 318is - Sold
                        Schwarz 1988 325is - Sold
                        Schwarz 1991 325i - Driven
