what to use to sculpt some drillable(and screw-able) tabs
  • static
    • Oct 2005
    • 501
    Hi
    I need some kind of compound that would dry to a strong-plastic-like state. Has to stick well to plastic and be sculptable when fresh (before it dries that is).
    Basically i am looking to make some tabs on a plastic part to accept screws (so has to be drillable and not brittle, so it won't split when screw is going in)
    Thanks
    Alex
  • ivo316
    • Oct 2006
    • 1222
    Use poliester resin (the resin from fiberglass) do not use epoxy resin, it is wierd when sticking to plastic (with some plastics sticks and on others doesn't).
    • static
      • Oct 2005
      • 501
      thanks, wouldn't it be too brittle for drilling/screws when dried up?
      • static
        • Oct 2005
        • 501
        anyone else has any ideas?
        • eko
          • Mar 2006
          • 372
          Cant you just use some small metal tabs,predrilled then bond them to whatever it is?
          94 316i Touring M52B28
          Made in Germany perfected in Britain!
          • 2002maniac
            • 4260
            epoxy putty?
            • AndrewBird
              The Mad Scientist
              • 11898
              What are you trying to attach the tabs to? As eko said, metal tabs might be easier, and you could always screw the tabs to what ever you want to attach them to. That is, depending on what it is.
