glove box lock broke in locked setting
  • Vedubin01
    • Jun 2006
    • 5852
    Is there a way to get the glove box open if the lock is stuck in lock mode. Is it safe to cut the lock out to replace with a new lock? Or is this going to take removal of the dash board to get to it?
    TIA
    V
  • eko
    • Mar 2006
    • 372
    Undo the bolts which hinge the glovebox and try and get access to the tabs on the catch?
    Only a guess as ive never tried!
    94 316i Touring M52B28
    Made in Germany perfected in Britain!
    • bddog
      • 351
      Eko is right. That's how I did mine. If this doesn't work for you, remove the screws from the piano style hindge on the bottom. This will give you a lot of wiggle room. This is a common problem. Latches are cheap.- Steve
