Decisions... Decisions...
  • Midnight Sun
    • Jan 2007
    • 429
    This is for my 1985 325e
    I got myself a complete 325i engine, except it is missing about 3/4 of the wiring harness. But I have the computer and injectors and whatnot.
    Where should I go from here... I see boost in my future. Keep that in mind.
    Can I just slap the I head onto my eta block? Should I just swap entire m20b25 engine into the car... Will it work with the eta's wiring harness?
    Is there some other hybrid that i dont know about that i can make between these two engines? This is kind of a budget build, and the car is my daily driver.
    Open to all ideas.
    Originally posted by Teaguer
    Filling an Eta's tank with super unleaded will reach the cars maximum attainable performance level .
    Aa a bonus filling the tank will also double any Eta's resale value .
  • xLibelle
    • Aug 2004
    • 2673
    MegaSquirt
    • 88e30is
      • Feb 2007
      • 690
      Originally posted by xLibelle
      MegaSquirt
      • Midnight Sun
        • Jan 2007
        • 429
        i am gonna run MS this fall after I turbo it. But untill then... What do you suggest for NA applications?
        • AndrewBird
          The Mad Scientist
          • 11898
          I would find an I harness and swap the entire engine into the car and run it until you turbo. Then pull it, stroke it, break it in and turbo it!
          You can't juts put the i head on an e motor. There are oil journals that need to be drilled to make it work. Hence why I said to just swap the whole motor in. Then you will have an i engine instead of a slightly faster e.
          There are several threads on doing the swap. Just search and you will find.
          • george graves
            • 19996
            3/4 of a harness? That's like being "kinda pregnant"....
            Keep your options open. If you MS and you re-wire yourself you can re-sell the harness. Get a good (know good) harness now and save your pennies for if/when you do a turbo/swap...
            Originally posted by Matt-B
            • Midnight Sun
              • Jan 2007
              • 429
              Well I bought it from a guy doing an S50 swap, and he needed to convert it to ODBI and the wiring harness got butchered in the process..
              I will get another harness, I just was not sure if I could use the Eta one or not. Any recommendations on where to buy?
              Thanks for the info guys..
