i just bought a 89 325i and have been tuning it up for quite some time now. When i bought the car the odometer did not work anymore and the coolant gauge was erratic. So i went to the junkyard and pulled an instrument cluster and everything works except the fuel gauge. therefore i think the problem is in the cluster and not the fuel sender relay b/c i am pretty sure th gas guage worked on the old one. What do i need to fix/repair. Any help appreciated. thanks Matt
fuel gauge
guage
Originally posted by JAM View Postdoes the fuel level read erratically at all times, yet the warning light comes on when your almost out of gas?
if so, that is exactly what my car does and it fucking pisses me off!!!
gauge
Originally posted by NitroRustlerDriver View PostDo you still have your old cluster? Your problem might have been as simple as needing new SI batteries.
If you want to keep the one you have, just get another fuel gauge and swap it out. I believe it is just held in place with a few screws, no special tools required.
