Remove cluster and car no run?
  • Brian 89 325i
    • 1450
    Today i took out my instrument cluster to put in new gears and i had to drive it a few places. Well when i got home tonight it seemed like the battery was dieing. The lights got dimmer and dimmer then nothing at all then the car stalled. WTF. Is this related or do i need an alternator? Please help.
    Brian
  • graphik
    • 361
    i drove around without an instrument cluster for a little while in one of my old e30s. so id say it might be something else.
    alex
    • grlaneriejr
      • 321
      I heard somewhere that if the battery charge light on some of the E30's didn't work, the alternator won't charge.
      If this is true, it sounds like it's what your problem was.
      Try charging your battery and seeing if that fixes it.
      Hope this helps.
      • e304lyfe
        • 807
        it is because you removed the cluster.. toss it back in, and charge your battery and you'll be good.
        • Brian 89 325i
          • 1450
          Cool, i hope thats what it is.
          Brian
          • kencopperwheat
            King of Kegstands
            • 14396
            Hope this helps.
            That was only on pre-85 e30s.
            *To me it sounds like the alternator.
            Originally posted by Gruelius
            • Brian 89 325i
              • 1450
              Well it MUST have been the cluster. I went out there and put the cluster back in and started it up. Ran it at fast idle for 10min and shut it off. Then started it up again. Everything should be cool. Thanks
              Brian
              • AdamF 88iS
                • 2051
                It's not just pre-85 cars. If you run any E30 with the cluster out then the charging system will disable itself because the warning light isn't there.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • Brian 89 325i
                  • 1450
                  Thats an interestingly retarded way to wire a car. Glad i know that now.
                  Brian
                  • arnoldgtr
                    • Mar 2004
                    • 153
                    The bypass resistor is still on the cluster circuit board. No cluster, no battery charge.
                    John
                    88 ///M3 Cinnabar
                    84 318i Black
                    • devarato
                      • Mar 2004
                      • 66
                      hahaha if only i knew this last week! .....
                      meh, needless to say we plugged it in and i was moving again
