Power window relay?
  • grlaneriejr
    • 321
    Power window relay?
    Hey guys, I got a question. Do our cars have a power window relay? I can't get my windows to work, and when I checked out a Haynes manual, it shows one on our cars.
    Does anyone know where it's located? The book doesn't tell me that much.
    Thanks.
  • kencopperwheat
    King of Kegstands
    • 14396
    Do you mean the circuit breaker in the dash (or maybe console)?
    Originally posted by Gruelius
    • Sean
      • 5793
      Yeah, that button catches a lot of people. Make sure that its down.
      - Sean Hayes
      • grlaneriejr
        • 321
        Guys, where is this button you are talking about?
        All I know is that my windows were popping the fuse constantly, and now they aren't doing anything at all.
        I'll go check for this button right now.
        • grlaneriejr
          • 321
          Please help guys. Where is this circuit breaker?
          • dgspikes
            • Mar 2004
            • 179
            i think you might be talking about the button thats next to the hazards button, i think right under the center vents
            • bmw4life
              • Apr 2004
              • 152
              not sure but is it the one near where the window buttons are? The one that is black and when you push it you can see red around the edges.
              • franz
                • 631
                It can be in either location, depending on where they put it at the factory.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  Yes, that button (plain black) is the breaker. If you can see red around the edges, then it's tripped. The breaker must be depressed in order for your power windows to work. However, if you're constantly blowing fuses, I don't think it's the breaker.
                  • Sean
                    • 5793
                    Yeah, maybe there's a bad ground? Or, the system just keeps shorting out? Something to try - get a new fuse in there, and try each window individually. After each try, check to see if the fuse is blown. That way you can narrow it down to one motor - then check wires related to that motor.
                    - Sean Hayes
                    • AdamF 88iS
                      • 2051
                      Early cars have the breaker button near the center vents like he said, after '88 the button is near the front passenger's window swtich by the shifter.
                      Adam Fogg- '88 M3
                      Common sense- It's the new 'gifted'
                      • grlaneriejr
                        • 321
                        I'll try that button.
                        All I know is that before it tripped, it would blow the fuse every time. I thought that I had a wire grounding out around the tranny tunnel, but I didn't.
                        I'll check that out later and let you guys know.
                        Thanks
