Plastics Swap Fog Lights???
  • jamiholzbach
    • 311
    does anybody know whats required to swap the fog lights when you do a plastic bumper swap? Just splice the connectors, or do the relays need to be changed,etc.???
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    they're just lights... + and -... Splice and solder the different connector on and you're set.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Jand3rson
      • 37587
      Don't even really need to solder, you could use wire connectors (not wire nuts) and be just fine, that's how we did my turn signals, and then just covered them in heat shrink tubing.
      • Garageaholic
        • Dec 2005
        • 5204
        Out of curiosity, why can't you use small wire nuts and electrical tape it all around.
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        • 88e30is
          • Feb 2007
          • 690
          Water will enter and short it or it will corode. The front of the car gets the most wet when its raining or if you hit a puddle. Be safe and soder or use wire butt ends and shrink wrap.
          • NC325iC
            • Mar 2004
            • 6565
            i just went through last week and soldered up all of my headlight connections and my turn signal connections, i went ahead and disconnecter the orange running lights so i could be euro cool
            • AndrewBird
              The Mad Scientist
              • 11897
              Wier nuts are not designed to be used in situations where there is vibration. Just get some Perma-seal style connectors that have heat shrink on them already. Crimp them, heat them up and the shrink wrap will seal down and make a water tight seal. No tape needed.
              Most also have a heat activated glue that seals the heat shrink to the wire, so there is NO WAY for moisture to get in.
              Napa sells them along with most other automotive stores.
              Here is what I mean:
