Engine Running rich anyone got any ideas?
  • ianosfritas
    • Apr 2007
    • 11
    yeah i put in a new battery, new spark plugs, new distributor, new spark plug wires any one got any ideas on what it could it be?
  • strad
    • Jan 2007
    • 241
    How old is the O2 sensor?
    any vacuum leaks at all?
    MAF clean?
    Coolant Temp Sensor for DME good?
    Do you have some numbers you could post?
    HC, NOX, etc, for idle and at speed?
    All I can think of at the moment.
    The current fleet:
    1992 325ic: 148k-171k miles
    1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
    1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
    • backtrail69
      • Jul 2005
      • 4471
      Have you given the ECU time to re-adapt after losing power?
      :: PNW Crew ::
      '87 325 4dr, '74 2002
      • ianosfritas
        • Apr 2007
        • 11
        the thing is if i dont warm it up for a good 2 to 3 mins it will stall because it idles at a 500 rpms and usually stalls so we took the idle switch off and it just idles at about 1500-2000 and we havent checked the o2 sensor.
        • ianosfritas
          • Apr 2007
          • 11
          and how much time and how do you mean lose power?
          • backtrail69
            • Jul 2005
            • 4471
            After you replace the batter the power is cut to the Motronic unit and it resets. It takes time to relearn the car. With the throttle switch removed it will run retarded timing and not correctly adjust fuel mixture for idle/ driving. Get that fixed and get back to us.
            :: PNW Crew ::
            • ianosfritas
              • Apr 2007
              • 11
              no it was running rich ever since i got it back in january and i just replaced the battery because it didnt hold a charge
              • AndrewBird
                The Mad Scientist
                • 11897
                What kind of spark plugs?
                Cold start valve?
                Idle control valve?
