Magnecor Wires
  • e30eta
    • Apr 2007
    • 27
    Magnecor Wires
    Alright did a search and didnt find the answer I was looking for. Im about to install new plugs and magnecor wires, the wires came with a little baggie of gold nuts and a note stating the following:
    "On some engines the orignal spark wire design calls for the spark plug terminal nut to be removed from the spark plugs, these must be replaced before fitting the Magnecor spark wires.
    If you spark plugs do not already have these nuts attached, screw the replacemnet terminal nuts supplied with this set on to your spark plugs and ensure that they are fully tightened before the Magnecor wire set is fitted"
    My question is, Is the ETA engine included in what is stated above? Do I need to put these on the spark plugs?
    Thanks
  • Mr Deagle
    • 1121
    take off the spark plug, and see if it is threaded or not on the end, if it isnt, reinstall and dont worry about it
    if there is a threaded portion, install said nut on said sparkplug on all 6 and reinstall
