turbo m42?
    but cheaper? i doubt it.
    98 M3/4/5
      Well you'd have to be doing R&D work almost to get a M42 turbo working, plus all the fears of screwing shit over. Whereas the SR20 is a trusty motor, and would be reliable.
      BMW SR20DET Conversion
      Below is a typical listing of the expenses you should expect to pay to have the engine installed.
      Complete engine with intake manifold with all sensors and 370cc injectors.
      Complete, plug and play harness and ECU, MAFS, CAS
      Distributor with spark plug 7mm wires and igniter coil.
      Garret T25 turbo, downpipe, and hardware.
      5-speed transmission with pitch fork and t/o bearing
      (S14 $3600)
      (S15 $5500)
      Custom Drive shaft, Yoke, Shifter, Bushings, Etc. $500
      Complete Exhaust System, in stainless steel, with performance muffler and tip.
      High Flow Cat optional. $800-900
      Motor and Trans mounts with hardware.
      No, we do not sell these separately, so please do not ask. $500
      Front mount intercooler, plumbing, hoses and hardware. $800
      Custom modified Radiator, Electric Fan and Thermostat, and hoses $275
      K&N-style Cone filter with MAF adapter $55
      Walbro Hi Flow Fuel pump/ Bosch High Vol. Fuel Pump $119/$245
      Dry Cell Battery, Tray, Wiring $109
      Clutch Kit: Starter, Flywheel, Clutch disc, Pressure plate, Pilot bearing, Throw out bearing, ARP Flywheel bolts $319-$495
      Rest of the stuff, too many little things to list here. $475
      Engine and trans delivery $150-$450
      Optional stuff.... CALL
      Labor - Including Install of above /Considerably cheaper if you do it yourself. $1500/$$Beer$$
      Could you please give me a price on the kit?
      For generalities the kit start at $5500USD to $6500USD, and will depend largely on the donor engine and transmission chosen.
      I am not mechanically inclined what so ever, so what costs am I looking at to get someone else besides me to do the installation.
      Figure about $2-3000 depending on who you ask, and how familiar with engine transplants and shop rates. We usually charge out about $3000, which also includes Dyno tuning.
      SR20DET (stock) 205hp to 280hp
      Modified SR20DET, with minor modifications and tuning 350-450hp
        im not looking for an outragious ammount of power. i just wannt a light nible 318 with a bit more bite to pull itself out of corners and down strait roads.
        im fairly sure me and 3 of my friends (2 of which have much turbo experience) could wip something home-made up without toooo much trouble. one of those guys has turboed 2 of his cars (going on 3), and one of the others just turboed his car for just under $1000 i belive. (and it runs great)
        i understand that an m50 would be a much better choice for the extra power, although it weighs much more than the m42.
        i think it would be a very fun project.
        98 M3/4/5
          lol my friend turboed his m42 with less than 1k
            how much horsepower does a $1k turbo setup make?
            BEERTECH
              Not sure because when he was about to swap the turbine for a bigger one, he crashed the car. :(
              I think he got about 150hp out of a small ass turbine that wouldnt let the car go past 5k rpm hehhe
                exactally
                my guess is that hes probly running a smalllll turbo at somewhere between 8-12lbs of boost.
                whats the stock hp of the m42? 140? soo im guessing a well set-up well tuned m42 turbo could easily make 220-260 crank hp. assumeing that 1psi = 10hp
                98 M3/4/5
                  Drew......8-12 lbs ????? On high CR?
                  My guess would be right at 6psi.
                  From the days of readng about small boost on Hondas, and about postive displacement in SCC, 40% increase in HP sounds reasonable, so 196hp at crank......maybe, if exhaust, intake, tuning is all good.
                    oook..didn't read all this thread..so forgive me. The next engine I get will have a CR of 10.4:1, and I will be running about 10 psi. I'm in no way worried abotu the engine, b/c it is alllll in the tuning. I'tll be Hondata tuned running 550cc injectors. If you tune the motor right and don't go freakin nuts on the boost, it'll run great. Please keep in mind that Honda's are notorious for weak ring lands too. :D
                      6psi is waffleswaffleswaffleswaffleswaffles boost. anything can take that... well almost anything.
                      10psi is really not THAT much boost. but i assume it can be stressfull on a motor like the m42 considering the hemispherical head (it does have that right) and the high CR.
                      either way, if i had a 10psi m42, i wouldnt be too conserned.
                      98 M3/4/5
                        Good Luck with that Drew, Pinging will PWN you! :P
                          bahhh ill show u!!!
                          hahah, anyway, i dont have a 318. i was just wondering why i had never seen it before.
                          98 M3/4/5
                            btw, if your interested in high vs. low compression. read this.
                            98 M3/4/5
                              8lbs on a B18B? Hmmmm, pushing it. That's like a Jackson Racing with a big pulley..... stressing a little bit. They don't have knock sensors. so get something wrong..... :evil:
                              I know you gots a B25, but I thought you were thinking about this as a project. That project would probably be a bust at 10psi.
                              Why not get a cheap M10, and boost it as much as you can. That'd be a stupid fast toy.
                                yea, i was thinking this would be a cool little project to fuck around with...
                                butttttttt, i have $2.42 right now and my source of income has been cut off temporarly (damn sports). so nothing like this is gona happen any time soon.
                                98 M3/4/5
