no electrical in car
  • jrobie79
    • Mar 2006
    • 2526
    for while i could hear a lot of squealing coming from my belts, im assuming it was the alternator belt cause i put some wd-40 on it and it went away temporarily. over the weekend i noticed some of the lights were flickering on and off on the instrument panel, the battery light, e-brake light and antilock brake light would flicker, at higher speeds them seemed to stay off. Today i went to go start my car and it wouldnt, so i got it jumped and it started but nothing electrical worked, no radio, windows took about 5 minutes to go down, no tach, speedo, gas gague, odometer, it just didnt work, so i checked the alternator belt to see if it was loose or something but its not, would you assume that a new alternator is all i need?
    1991 318i ---- 308K - retired
  • backtrail69
    • Jul 2005
    • 4471
    Jump the car and see what the output of the alternator is. Should be something like 13-14 volts at least. You can also bring it into the parts store and have them test it. A lot of places have alt testing.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • jrobie79
      • Mar 2006
      • 2526
      how do i check the output?
        It really sounds like your alternator is producing enough power to keep the battery charged. And now the battery is low enough that the electricals are flaky.
        The cause could be a bad alternator, slipping belt,or even a bad battery. Having the battery and alternator tested should tell where the problem(s) is.
