noise from center of car, driveshaft ?
  • Jordan325iC
    • Aug 2005
    • 1697
    I had this noise pop up during an autocross. After the autocross, I jacked up the car to figure out what was making the noise, couldn't find it, put it back on the ground and it stopped making the noise. It was quiet for a few weeks, then it came back with a vengance a week ago.
    Car: '88 325is, 250k miles, lowered w/ LSD.
    The noise:
    -Sounds like the wheel from "wheel of fortune".
    - Correlates to wheel rotation, not RPM.
    - Really loud, undrivable.
    - Pretty much constant, happens loud under braking, intermittent during turning.
    According to the GF outside car:
    Comes from underneath the cabin, equally loud on both sides. Like it's coming from the driveshaft tunnel.
    When I jacked up the rear of the car and turned the wheels, there was a slight noise coming from the driveshaft underneath the exhaust.
    Does anybody have any ideas?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • ColdAccord
    • 5926
    check the center support bearing
    Originally posted by blunt
    • mattdk318i
      • Jun 2006
      • 3953
      Csb
      • Dibo718
        • Oct 2006
        • 137
        When i first bought my car i had a similar problem, same sounds and everything... it was the U joint.
        • Jordan325iC
          • Aug 2005
          • 1697
          As of now, I know the CSB is completely gone, and the driveshaft was dragging on the heatshield. I'm going to replace the CSB and see if that helps.
          '88 325is
          BMWCCA 380364
            If the rubber mount around the center bearing is gone simply replacing the CSB will be at best a short term fix. The usual cause of the mount failure is binding drive shaft u-joints tha place unusual loads on the CSB. Replace both at the same time.
            • HST
              • Jan 2006
              • 757
              also do the guibo (sp) when the CSB goes out it weakens the guibo.
              Originally posted by KingB
              Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
              • Jordan325iC
                • Aug 2005
                • 1697
                I ordered the CSB with mount, I believe. I ordered this:
                Correct?
                The guibo looks ok, no shredding or anything. I've got a rallycross tommorow which I can't miss, so I'll just have to hope everything works out.
                '88 325is
                BMWCCA 380364
                • thectrlguy
                  • Apr 2007
                  • 1042
                  Any other symptoms? Clutch shudder/disengagement issues? Have you removed the driveshaft / transmission?
                  • Jordan325iC
                    • Aug 2005
                    • 1697
                    Clutch works fine. It became a little light after I left it sitting for a while, but I think that's because air is in the system. The whole car has a shudder, but I noticed that my tranny mounts were broken in half, so that might be contributing, and I've got two new ones to install to see if that helps. I haven't completely removed the tranny, but the driveshaft is out. I'm in the process of installing the new CSB right now.
                    '88 325is
                    BMWCCA 380364
                    • thectrlguy
                      • Apr 2007
                      • 1042
                      According to the BMW TIS, thing to verify/check
                      a) Propeller shaft not aligned precisely
                      b) Runout on centring spigot, transmission flanges or final drive flanges
                      c) Center mount damaged
                      d) Universal joint worn or seized
                      e) Engine/Transmission suspension not OK
                      f) Joint-disk rubber damaged
                      g) Centre mount not perpendicular to propeller shaft, not at all or insufficiently preloaded
                      • Jordan325iC
                        • Aug 2005
                        • 1697
                        I forgot the order of things when I took off the old CSB. When you are banging on the new CSB, does it go:
                        #1 dustshield - csb - dustshield - circlip
                        OR
                        #2 dustshield - csb - circlip - dustshield
                        #1 would make more sense to me, but I can't seem to get the new bearing on far enough for that to happen, it seems like it's as far as it can go.
                        '88 325is
                        BMWCCA 380364
                        • thectrlguy
                          • Apr 2007
                          • 1042
                          This website is for sale! ee1394.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, ee1394.com has it all. We hope you find what you are searching for!
                          • Jordan325iC
                            • Aug 2005
                            • 1697
                            That site doesn't explain where the circlip should go.
                            '88 325is
                            BMWCCA 380364
                            • thectrlguy
                              • Apr 2007
                              • 1042
                              Sure it does,
                              Dust cap > bearing > dust cap > circlip
