Mod Power Steering
  • e30Matt
    • 5077
    "1.84kg" says the ETK... about 4 pounds.
    • MattM20
      • 641
      Originally posted by Charlie
      Originally posted by MattM20
      is the power steering fluid also used to lubricate the steering rack without power assist? ive got my first track day comming up in a week and i'm worried that i wont be let on the track with a leaking steering rack, so i was considering draining the fluid and disabling the power assist. i'm not too worried about hurting my steering rack since i'm getting it replaced very shortly, i just dont want my steering rack gears to lock up on me at any time
      Haven't you had the car teched yet?
      They'll tell you whether or not it would pass. Is it actually leaking, or just oozing out of older hoses? An actual leak (one that requires regular refills) would be an issue, the normal seeping and oozing of old hoses won't get you flagged usually, mine aren't in the best of shape, but I haven't been called on it yet. No big deal, I'm replacing them this summer anyway.
      -Charlie
      no, i need to have tech inspect it before the let me on the track though. its only leaking from the drivers side steering rack boot, but its very noticeable, especially when the car is on a lift and the tie rods are angling towards the ground
      • Rob
        • 8166
        so much for the weight savings, i'll just take a dump....
        BEERTECH
        • elemental
          • Jan 2004
          • 112
          What ever about the weight, dose the PS fluid lube the rack. should it be left full or just sealed,, still up in the air going to pull the belt check it out,..
          • MattM20
            • 641
            bump
            • george graves
              • 19998
              Car and driver's only complaint of the e30 m3 (if I remember right) was that it had too much assist...
              Originally posted by Matt-B
              • Rob
                • 8166
                car and driver also calls an e46 325 'sporty' :P
                BEERTECH
                • decay
                  • 5637
                  Originally posted by M-technik-3
                  Screw that dump the PS rack for a simple manual rack. Then you won't have any worries about it.
                  i remember reading somewhere that all e30s had power steering... was that wrong? does it only apply to US-market cars?
                  past:
                  1989 325is (learner shitbox)
                  1986 325e (turbo dorito)
                  1991 318ic (5-lug ITB)
                  1985 323i baur
                  current:
                  • Brew
                    • 3060
                    Indeed.
                    '91 318is
                    • decay
                      • 5637
                      Originally posted by Brew
                      Indeed.
                      for clarification, that's yes to both, meaning i'd have to source a manual rack from overseas if i wanted one?
                      past:
                      1985 323i baur
                      current:
                      • Nate325ic
                        • 462
                        for those who think they have to much assist you must've never driven any other power assist equiped cars, I think the e30 is perfect
                        • Brew
                          • 3060
                          Indeed.
                          Yeah. Talk to Greg (m-technik-3). He can probably hook you up. I'm planning on getting one at some point.
                          '91 318is
                          • decay
                            • 5637
                            thanks for the lead- if i decide i really don't like how an unpowered rack feels, i'll follow up :)
                            past:
                            1985 323i baur
                            current:
                            • eliasmavs99
                              • 58
                              I did it on two cars. On the 318, the steering stiffened a little but its still very managable. On my 325i, after taking it off, it was really stiff at low speeds (<10MPH). Just think of it as a work out for your arms. I would recommend it because it frees up some power.
                              • elemental
                                • Jan 2004
                                • 112
                                Well the belt came off this after noon, at first impression I like it alot! more feedback all around,. steering style is going to change abit I think!
