Not e30 but maybe you guys can help e36 cluster lens removal
  • BingM3
    • 863
    I am helping a friend replace the gauges to white on his car BMW e36. However, after removing the 2 screws, we got the cluster out and the clear lens is intact. Is this glued or something, we need to remove it. Any ideas? Thanks.
  • DaN
    • 1265
    Most likely you need to take all the screws out on the back, and split the case open.
    This is how e30 VDO clusters are set up, I would imagine e36 clusters are similar.
    • Ryan Stewart
      I Love Miatas
      • 8978
      Yes, it comes out the back. The clear plastic is glued around the front and would be ruined if removed.
      Im now E30less.
