rear end gets loose on the freeway
  • crazynoll
    • Feb 2007
    • 54
    so ive notice this quite a bit is it comon for the car to shake side to side. the rear end feel like its rolling with the groves of the freeway.
    <img src=http://www.r3vlimited.com/board/image.php?u=14143&dateline=1175417424&type=profile >
  • Mike325
    • Mar 2006
    • 3685
    Get an alighnment. I know the rear is non adjustable without sepecial bushings, but that will tell us where your car is at. I believe that too much toe one way will cause the car to do this. Have you checked your tire pressures?
    Originally posted by Kershaw
      Worn trailing arm or subframe bushings can cause the rear of the car to feel unstable, especially at speed.
      • crazynoll
        • Feb 2007
        • 54
        i had the alighnment done when i put my new rack in im think it could be subframe bushings or trailing arm
        • eighteight325is
          • Apr 2006
          • 204
          What sort of tires are you running? I've heard some tires that are right on the edge of being dedicated competition tires that are still street legal are more prone to tram-lining in small grooves in the pavement.
          • crazynoll
            • Feb 2007
            • 54
            just regular tired nothing performance i havent balanced the rears yet tho
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              Rear subframe bushings are worn.
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
