How do i get the cluster out?
  • golde30
    • 11464
    ok, so on my 90 325i, i am tryn to get the cluster out, but the panel below the cluster and above the steering column is blocking the screws...i pulled that fucker, and it flexes a whole lot, but doesnt pop out...where are the screws located on this panel, and how do i get to them? thanks
    -cary
    IG: @Baye30
  • Chris325/325i
    • 40
    Remove the kick panel under the steering column, then you can reach up and behind the dash area. There are two large knurled nuts that hold that long skinny panel on.
    • aaron_silva
      • 1785
      Step by step with pictures.
      Aaron
      • golde30
        • 11464
        hmm...going underneath would work on my 88 w/o airbags...but the dash in the newer airbag cas has that fat metal panel behind the lower kick panel...i will take a look 2day. thanks
        IG: @Baye30
        • DaN
          • 1265
          Mine just pops out, it slides onto these brass looking things that hold it in place. There is one on the far left and far right. I think :oops:
          • ///M42 sport
            • 3952
            That long skinny part above the steering column is the hardest to get out. It'll feel like its almost about to break. (That is if you leave the steering wheel on.)
            ________
            Buy cannabis seeds
            • Erick
              Official R3V Drifter
              • 11169
              I did it on my '89. Easiest thing ever. Definetly no more than a 1 hour job to remove it if you are the worst newbie doing it for the first time.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • Bryson
                • 1490
                it's infinitely harder to do on an airbag car, smart ass
                after you've got that fucker out grind the back center out of the bracket if nobody has done so in the past to make removal/installation easier, closer to the 89- cars (the grinding is standard mechanic practice
