so i'm assuming my slave cylinder is gone. there is a small pile of fluid under the trans. the car is at my apartment right now. is it possible to drive it still? can i manually pull the clutch pedal up to engage it? it'd be nice if i could get it over to my buddies place about 5 miles away.
clutch stuck to the floor... still driveable?
pulling up the clutch pedal won't engage the clutch.
You'll probably have to start the car in gear, then rev-match your shifts. to stop, pull it out of gear and stop normally, then shut it off and put it in gear. start the car when you need to start moving again.
This is only a temporary solution (ie, get me to the shop) as it will damage the transmission synchros over time.Eric Austin
1990 325i Sterling Silver
///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
Originally posted by StrokedSix View Postso i'm assuming my slave cylinder is gone. there is a small pile of fluid under the trans. the car is at my apartment right now. is it possible to drive it still? can i manually pull the clutch pedal up to engage it? it'd be nice if i could get it over to my buddies place about 5 miles away.
GL!
Luke
