I'm interested in modifying the stock aux fan so it runs on high all the time ONLY when the A/C is on. In other words, I don't want the fan to run on high all the time, just during A/C operation. I don't know much about electrical schematics but I'm pretty good with a solder iron. Can this be done? Thanks in advance!
Stock aux fan mod
I thought that the fan is on high all the time when the a/c is on to help cool the condenser.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
That could be done, but why? Under normal operation the speed of the aux fan is controlled by temp sensors in the radiator. There's no reason to run the fan on high speed if the radiator temp is low.
If you are trying to cure an overheating problem you need to identify and fix the cause rather than treating the symptoms.The car makes it possible, but the driver makes it happen.
I had done this when my aux fan resistor was bad. I jumped terminals from the low speed relay to the high speed relay. I just used a piece of wire, like 12-14awg. Jumped the control side of low speed, to control of high speed, in your case youll need to leave the low speed relay out, since your resistor is ok.
Originally posted by jlevie View PostThat could be done, but why? Under normal operation the speed of the aux fan is controlled by temp sensors in the radiator. There's no reason to run the fan on high speed if the radiator temp is low.
the system is going to cool.Last edited by AlpineIS; 05-21-2007, 08:08 AM.
