cheap way to relocate FPR?
What you do is install the 17lb or 19lb injectors with the 2.5 bar FPR and it just gives the ecu an easier learning curve. You then install the 3 bar FPR and it will adapt quicker. My car just ran alittle rough on the 19s untill I drove it for like 20 min, but it ran alright with the 3 bar.
Moral of the story 19lb injectors are alot for a stock or even mildly modified e30, you really don't need to go that big. If you wanted to upgrade I would recommend the 17lb injectors in the m50.:: PNW Crew ::
'87 325 4dr, '74 2002
