ATTN: 153 to 173 Swappers...help?
  • StereoInstaller1
    GAS
    • 22679
    Hi.
    So I understand that the way to get the ECU to flash codes after a 173 swap is to floor the gas pedal 5 times, rythmically.
    I have had a CE light a few times, generally after a few miles of freeway time then restarting. Lots of freeway is usually no issue, but 10 to 15 miles, it lights.
    So, I have tried the whole "5 complete pumps" slow, fast, meduim, whatever.
    No flashie.
    Help a brother out, would ya? Am I having an issue with the TPS or something?
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
  • James Crivellone
    Head Janitor
    • 6305
    turn the ignition key to the On position (but dont start it), then: fully depress the accelerator pedal, then fully release it. Repeat the depress,release cycle 5 times fairly quickly, but not too fast. It should be completed in a few seconds. What you are doing here is clicking the wide open throttle switch then the idle switch each 5 times. This signals the Motronic unit to send the fault codes by flashing the Check Engine light. You should see the light flash once then it will start flashing the 4 digit codes. If there are no faults, you should see the 1444 code (and 2444 if you have a 12 cylinder). The codes appear as a series of flashes for each digit. The flashes indicating one digit are about 1 second apart, the next digit appears after a couple second interval. The rest of the fault codes appear in Table 1 below.
    DME Control Unit 1211
    Air Mass/Volume Sensor 1215
    Throttle Potentiometer 1216
    Output Stage, Group 1 1218
    Output Stage, Group 2 1219
    EGO(O2) Sensor 1 1221
    EGO(O2) Sensor 2 1212
    Lambda Control 1 1222
    Lambda Control 2 1213
    Coolant Temp. Sensor 1223
    Intake Air Temp. Sensor 1224
    Knock Sensor 1 1225
    Knock Sensor 2 1226
    Knock Sensor 3 1227
    Knock Sensor 4 1228
    Battery Voltage/DME Main Relay 1231
    Throttle Idle Switch 1232
    Throttle WOT Switch 1233
    Speedometer A Signal 1234
    A/C Compressor cut off 1237
    A/C Compressor 1242
    Crankshaft Pulse Sensor 1243
    Camshaft Sensor 1244
    Intervention AEGS 1245
    Ignition Secondary Monitor 1247
    Fuel Injector 1 (or group 1) 1251
    Fuel Injector 2 (or group 2) 1252
    Fuel Injector 3 1253
    Fuel Injector 4 1254
    Fuel Injector 5 1255
    Fuel Injector 6 1256
    Fuel Injector 7 1257
    Fuel Injector 8 1258
    Fuel Pump Relay Control 1261
    Idle Speed Actuator 1262
    Purge Valve 1263
    EGO Heater 1264
    Fault Lamp (check engine) 1265
    VANOS 1266
    Air Pump Relay Control 1267
    Ignition Coil 1 1271
    Ignition Coil 2 1272
    Ignition Coil 3 1273
    Ignition Coil 4 1274
    Ignition Coil 5 1275
    Ignition Coil 6 1276
    Ignition Coil 7 1277
    Ignition Coil 8 1278
    Control Unit Memory Supply 1281
    Fault Code Memory 1282
    Fuel Injector Output Stage 1283
    Knock Control test Pulse 1286
    No Failures 1444
    • StereoInstaller1
      GAS
      • 22679
      I have done exactly that about 10 times...no flashie...maybe bad TPS?
      Luke
      Closing SOON!
      • James Crivellone
        Head Janitor
        • 6305
        Luke
        Possible, how does the car idle?
        • Jean-Claude
          • May 2007
          • 8
          Whoa, James, I had no idea revlimited was yours.
          This is oHshiz from [m]. ;)
          1989 325i slushbox
          • StereoInstaller1
            GAS
            • 22679
            So damn snarly it is hard to tell, but the tach does not bounce.
            Do you know what wires are TPS on the ECU?
            What spec should I meter for?
            Thanks for the input!
            Luke
            Closing SOON!
            • James Crivellone
              Head Janitor
              • 6305
              Luke
              The TPS is just a switch, so just check continuity.
              PIN 1 = Brown/Blue = Throttle Closed
              PIN 2 = Brown = GND
              PIN 3 = Brown/Black = Wide Open Throttle
              Thats at the TPS itself, if you want ECU pins then its
              PIN 52 = Throttle Closed
              PIN 53 = WOT
              • StereoInstaller1
                GAS
                • 22679
                something tells me my TPS is not working properly.
                Only continuity, huh? Oh yeah, it is the E36 that uses a rheostat.
                Duh.
                I will test with my meter soon.
                Thanks!
                Luke
                Closing SOON!
