I took my transmission off, and changed the clutch. Now that its back together i zero clutch petal it just falls to the floor. So i thought i would bleed the clutch to see if it makes a difference. When im bleeding the clutch no fluid comes out of the slave cylinder. I pump the petal then just let it stay on the floor, then when i loosen the bleeder screw i here a little burst of air but no fluid. Could something be installed in my clutch wrong, or the slave cylinder isn't working? thanks
Clutch problems need HELP!!
