Coolant Sensor
  • winstontj
    • Mar 2007
    • 500
    Coolant Sensor
    Is there something I'm missing? I'm about 99.999% sure that I've got a coolant leak through the head gasket into one of the cylinders. Water has been dissapearing from the fill tank about a cup every 500 miles or so. I've been filling it up a cup at a time when the coolant light on the dash/roof flashes. Today the light came on like usual and I filled it after letting the car cool for a few hours only this time when I restared the car the light didn't go off.
    Is there a reset or something I'm missing? There is plenty of coolant in the system. There is nothing crazy like water & oil mixing so this is very straight forward. Should I check anywhere else for a coolant sensor? Would it be worth anything to check the sensor in the top of the fill tank? I assume this is what is triggering the light?
    Any thoughts or help would be appreciated.
    Thanks,
    TJW
  • Dave
    E30 RAT
    • 11675
    Yeah - its the sensor in the plastic overflow/fill tank. They go bad from time to time.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • PiercedE30
      • Apr 2005
      • 4220
      Yea, that sensor can go bad. All it is is a magnetic trigger. The coolant itself actually destroys the sensor itself leading you to replace it.
      My 2.9L Build!
      • FredK
        • 14763
        Just curious, do you have any white residue on your plugs?
        • winstontj
          • Mar 2007
          • 500
          white plug residue
          the car is only a few months old & I replaced the plugs ~3,000mi ago. I plan to pull them & post up some pics soon. No idea though why? I plan to find one or two that are different than the rest, if not maybe its not a head gasket...
          • psloan
            • 9815
            Winston, replace the sensor. You're putting in too much coolant and it's pouring out of the overflow tank. Mine does the same..
