ECU #153
  • mph
    • Jan 2004
    • 536
    ECU #153
    How do I open a 153 ECU? There are 4 larger screws and 2 smaller ones: I removed both. There are also two plastic tabs that can be pulled out: I pulled those out. I can't find out how the ECU opens up.
    Does the black internal part pull out from the aluminum case, or does the one side of the case pull off?
    It's a 153 ECU from a 1986 325iC, Euro (not sure if it makes a difference with years and what not. Any ECU 153 should be the same.
    Anyone have any ideas?
    Current BMW's:
    2004 330Ci
    1986 European 325i cabrio
    1986 735i
    Previous BMW's:
    1989 325is RIP
    1989 325iX RIP
    2001 740iL RIP
  • rs4pro3
    • 5808
    On the 153 I had you had to bend up the metal tabs on the cover and pull the cover off the main board then seperate the two boards to get to the chip.
    85 325e 2.7 ITB'd stroker
    • mph
      • Jan 2004
      • 536
      Thanks. I figured it out, but it's a huge pain in the ass compared to the other ECU's.
      Current BMW's:
      2004 330Ci
      1986 735i
      Previous BMW's:
      1989 325is RIP
      1989 325iX RIP
      2001 740iL RIP
      • fporro
        • 1860
        try to find a 173, it will idle a lot better :)
        straight swap from 1.1 to 1.3 motronic, perfect upgrade on my 87 325ic :)
        • Low Level E30
          • 1646
          What's the difference between a #153 and a #173?
          Obviously the #173 is newer......
          .... so how is it -better- ?
          • fporro
            • 1860
            # 173 gives better idleing and somewhat smoother reving. you still get a good kick at 3500 rpms.
            as per fault codes, it flashes more of them than 1.1 motronic units. so it's easier to pinpoint trouble.
            swaping chips it's easier too :)
            • bimmerphile
              • 3495
              If you replace the whole ECU, can you put a 173 ECU in a 153 car?
              • fporro
                • 1860
                yeap, that;'s what i did on my 87 325ic.
                the 153 started to fail, car would hesitate at w.o.t. between 32 to 3500 rps, sometimes it was truble free fopr a few days then go in a binge.
                swaped countless parts, like fpr, fuel flter, maf, cap, rotor, plugs, pts, and who knows what elese.
                eventually found a 173 at local yard, in she went and g'by to troubles a waived :)
                # 173 has a 3rd row of pins, that's ok, if you look at yoir harness you'll see a 3rd row as well.
                • mph
                  • Jan 2004
                  • 536
                  Well, it might just be a good time to upgrade ECU's. I broke one of the resistors when I went to put the chip in. Now the ECU makes a low pitched humming noise.
                  Current BMW's:
                  2004 330Ci
                  1986 735i
                  Previous BMW's:
                  1989 325is RIP
                  1989 325iX RIP
                  2001 740iL RIP
                  • jtuner
                    • Oct 2004
                    • 483
                    Sooo... I was running a 021 ecu in my 325e.. i switched to the 027 ecu and don't see much difference.. Would i be able to put a 173 in my car? This seems to be the best ecu all around wherever i look...
                    Project e30 m3 starts now..... :D
                    • Fred
                      • 659
                      No. The 153 is Motronic 1.1, the 173 (and higher) is Motronic 1.3, which why it is an upgrade for 325i's. Both the 021 and 027 ECUs are Motronic 1.0 (and have no real difference, besides the 027 has a detachable chip and the 021 is soldered) and are not compatible with different versions of Motronic; if you compare the pins, the eta has a two row connector while 325i's have a three row.
                      '86 325 2.8i stroker - Arctic Blue
                      '11 328i Sports Wagon - LeMans Blue
                      Strictly Eta
                      • jtuner
                        • Oct 2004
                        • 483
                        ahhh ok cool.. i figured it wouldn't work since nothing else fits on the 'e' that fits on the 'i's :) Thanks for the info.. guess best I could do for this car is the chipped 027.. Unless i get this ix, then it's open forum for me once again :)
                        • cyrmanj
                          • Oct 2007
                          • 251
                          This means that 153 chips (like a Dinan for example) works fine on a 173 ECU? If that is true why are they advertised differently?
                          Thanks
                          e30 diamantschwarz 325i
                          http://www.flickr.com/photos/cyrmanj/
                          • lordofthewaters
                            • Oct 2005
                            • 714
                            Thanks
                            No. 153 chips work ony in 153 dmes. The 380 can use 173 chips and vice versa however.
                            Sarcasm is a body's natural defense against stupid.
                            When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                            "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                            Old age and treachery will always overcome youth and skill.
                            • everlast
                              • Oct 2004
                              • 225
                              My '88 "i" started a lot easier with the 173 upgrade. Also gives you the ability to do the "stomp" test for Check Engine Light. The 153 only has a limited number of codes.
