Door Catch Point
  • taylor89
    • May 2007
    • 35
    Door Catch Point
    On my 86 325es the driver side door won't seem to "catch" halfway into its swing. Where is the mechanism that does this and where can I get the parts to fix it?
    Also, I took the car in to get the a/c replaced and the guy wants 1500 to get a new compressor, drier and expansion valve. This seemed pretty steep to me... Is he ripping me off or should I expect to pay this much wherever I go?
  • wickedE30
    • Sep 2006
    • 699
    you can get the expantion valve and the drier new ,for like $65 including shipping.I got mine in ebay and has worked execellent.I'm sure you can get a new compressor for no more that $500.That guy is fucking crazy or he thinks your stupid.
    88 M3,88 325ic,87 325is
    e30s are like fat girls that USED to be hot, you just gotta work them out to make them hot again.
    • browntown
      • Jun 2004
      • 3524
      dear god, 1500$. Even if it was true and it did cost that much to buy, I'd ditch the a/c and call it a weight savings mod. 1500 goes a long way towards a motor, paint, bling wheels, seat upholestry. Pick your project, a/c is waaay down the list.
      • taylor89
        • May 2007
        • 35
        That's what I thought. Just to clarify, that's with labor, but it still seemed extremely expensive to me. Thanks for verifying.
        What about the door catch point?
        • brandondan1
          • 1091
          You can buy the mechanism here, and it's located near the door hinge. If I remember correctly, you're going to have to remove the door panel and the plastic insulation. Knock the 'guide pin' (that the mechanism pivots on) out using a hammer. Then, unbolt the two bolts holding it to the door, and slide the old mechanism through one of the holes in the door. Installation is reverse of removal.
          http://www.bmaparts.com/epcksoap.epc...entid=bmaparts
          type specE30 in for the coupon code for 10% off
          91 318is
          • browntown
            • Jun 2004
            • 3524
            think they're called door brakes. That pin is a bitch to get out. go to the junkyard, 5$
            • StereoInstaller1
              GAS
              • 22679
              Fuck that, man...why have junky old used parts?
              I have a brand new one...sitting right here...I will even put it in for you!
              only $1500
              welcome to R3V.
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • browntown
                • Jun 2004
                • 3524
                Seem to remember you asking me to pull that very part out of the junkyard.
                • StereoInstaller1
                  GAS
                  • 22679
                  Shhhhhh! I am trying to make some money here, man, be quiet!
                  Closing SOON!
                  • browntown
                    • Jun 2004
                    • 3524
                    I'm all for you making money, maybe I'll see some of it ;)
                    • taylor89
                      • May 2007
                      • 35
                      Thanks a lot. The parts are on their way.
