I have been having this intermittent problem with my speedometer where every once and a while the needle will drop. Normally it doesn't happen very often and if i tap the cluster it pops back up.
Over the past few days it has gotten a lot worse and happens every time i drive. And today when I was coming home from work I couldn't get the needle to come back up by tapping on the cluster.
This is the only gauge in my cluster that is wonky.
What is causing this problem, and how do I go about fixing it?
