Rev Counter and MPG gauge problems. SI board and fuses good.
  • 337
    • Sep 2006
    • 14
    Hi, I've done a lot of reading to see why my rev counter and MPG gauge isn't working.
    -SI batteries are good
    -I've changed fuses # 10, 19 & 21 (They weren't blown)
    Any other leads as to what to check next?
    Thanks,
  • whiltebeitel
    • Apr 2007
    • 2098
    re-flow the connections on the board?
    '89 325i track sloot
    '01 530i daily
    -Enginerd
      The next things to try would be a different tach, SI board, and DME. The easiest diagnostic would be to temporarily swap in a cluster that is known to work properly. If that fixes the problem the cause will be the SI board or tach. If it doesn't the DME is cause.
      • 337
        • Sep 2006
        • 14
        Thanks for the help!
        The DME is an other name for the ECU?
