Blinkers not working, I've been told it's the relay?
  • optimusp517
    • Oct 2005
    • 797
    So my blinkers are not working when I turn them on, my hazards aren't either.
    I've been told it's the relay and the relay is in the hazard signal switch as well. Is that correct? If so I need to order one asap! I hate driving w/o blinkers and it's freakin dangerous!
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    dumb question but did you check the fuse? USE A DMV, looking isnt good enough sometimes. if you did and its good use get a flasher relay, its located under the steering column.
    • optimusp517
      • Oct 2005
      • 797
      I've checked that already. No fuses out, it comes in and out on my car. So it's the flasher relay and it's located under theh steering column and not in the middle where the radio is located where the hazard signal is?
      • Mike325
        • Mar 2006
        • 3685
        Ya, it's in the colum.
        Originally posted by Kershaw
        • optimusp517
          • Oct 2005
          • 797
          Now the real question is if it's the flasher relay or my hazard switch...
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            well, does it do the same thing when you use the turn signal? if so then its your flasher
            • Mike325
              • Mar 2006
              • 3685
              The hazards and the turn signals both use the same flasher relay.
              • Mr Deagle
                • 1121
                Nothing will work if the hazard switch isnt working
                i think the circut is like this:
                Turn signal lever, hazard switch, relay, blinkers
                • thectrlguy
                  • Apr 2007
                  • 1042
                  I would think it's the flasher, as the hazard switch should fail in one position or the other.
                  See attached drawings.....
                  • optimusp517
                    • Oct 2005
                    • 797
                    It was the flasher relay.
                    I picked one up from Patrick at BMA and thank goodness I live 2 states from him. Got it yesterday threw it on today after work and shazzzam! My blinkers are now working and I feel much safer :)
                    • thectrlguy
                      • Apr 2007
                      • 1042
                      Good times......
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        how much did u pay for a bmw flasher relay? well its bosch i guess but how much?
                        '89 Alpine S52 with goodies
