I've done something really stupid!
What sort of tests can I run to figure out if I fried the computer?
I have a rev counter that doesn't work, so I tried to wire it to the coil to see if it would start working.
I used that 3 pin connector that sits near the computer for the tach lead. The car wouldn't start with this connector unplugged, so now here's where I wasn't thinking... I wired the lead from the negative side of the coil into the the lead for the tach while the 3 pin connector was still plugged in, and the engine stalled.
Needless to say, the car doesn't start or run anymore, and I don't think I blew a fuse since there were none burnt. If there is a chance that I blew a fuse, which one would it be?
Anyone have any thoughts?
The car is an '87 325e
