odd sound
  • NC325iC
    • Mar 2004
    • 6565
    odd sound
    alright, this weekend i changed my water pump and my tstat, to do this i basically pulled the front of the engine off
    now its running well except for a strange sound, to me it sounds like a metal on metal rubbing/squeek sound, i think it may be the rotor on the points in the distributor, does anyone else have any ideas?
    also, before this it was making a sound that reminded me of the fan hitting something but it wasnt hitting anything so i took the dist cap off and put it back on and now the noise has either changed or this is a new sound
  • emi325i
    • Oct 2006
    • 356
    belt walk, maybe? my t-belt started to come off the pullies, and was grinding against the cover. I could see rubber residue/dusting coming out from under the t-belt cover on the driver side of the engine... you can shine a flash light and be able to see if that's happening to you.
    • NC325iC
      • Mar 2004
      • 6565
      the belt looked fine when i saw it i did a sort of pulse check type thing and i could only feel the "grinding" in the water pump so im gonna take it back off and have a looksy
