removing and caping off ac system...where to get caps?
  • george graves
    • 20003
    I want to cap off my ac system at the firwall and remove everything for a upcomming motor swap.
    Anyone know where I can get a metal threaded cap to plug the lines off? I tried local repair shop - and all I get are blank looks.
    Any ideas?
    George Graves
    Originally posted by Matt-B
  • rs4pro3
    • 5808
    Why do you need to cap it off? the only item needing capped would be the compressor once you pull it off. If you ever decide to reuse the ac system a shop will evacuate the system getting rid of anything that may of gotten in the lines.
    85 325e 2.7 ITB'd stroker
    • DaN
      • 1265
      You would still want to cap it off somehow. A metal screw on cap is not neccesary, a rubber plug or cap will also do. You want to prevent moisture, dust, animals, corrosion and insects from entering your lines.
