I have a problem that doesn't seem to want to go away. Every time I start my car cold it takes an average of 60-90 seconds of cranking intermittently to get it started, which can't be good for my starter. Every 20 seconds or so it sounds as if it is starting up, so I try to give it a little gas and it immediately dies.
The odd thing is that is runs at 100% after I get it started. I do not have any liquid leaks of any kind that I know of. I've replaced the distributor, cap & rotor, fuel filter, air filter, ignition coil, spark plugs, spark plug harness, ICV, and the cold start valve. The only other thing I can think of to replace is the fuel pump/relay, which I will be doing later this week.
Does anyone else have any ideas?
