MAF and Chip??
  • 87-325ic
    • Apr 2006
    • 1198
    MAF and Chip??
    So what happens when you have a chip, and you also want to run the e36 MAF conversion using the apexi unit?
    what does the computer do for fuel? i know it will use the chip's timing tables, but does it still get fuel info from the chip?
    i guess the apexi just tells the computer the "false" (since it converts the signal) signal, and the computer works as normal thinking nothing is different?
    is my logic right?
    help me out please.
  • Mr Deagle
    • 1121
    The apexi will send out a signal that mimics the flapper AFM
    the motronic will get all of its info from the chip
