Changing ECU from 0 261 200 027 ---> 0 261 200 021
  • elemental
    • Jan 2004
    • 112
    I have an 85e that has the stock ECU # 0 261 200 027, I have a freind that has a Authority Performance Engineering Chip in a 0 261 200 021 ECU for a 84e Could I change the whole ECU with out any prolbrems? As far as I have found the difference is the 027 has a detachable chip, is that they only differance,? Thanks
  • BS87
    • 1606
    Uhhh, going from 027 to 021 would be a downgrade............ and how did your friend manage to get a chip in the 021, which does not have a removeable chip?
    • elemental
      • Jan 2004
      • 112
      Not sure what the lineage is on it, Even when the ecu's chip cant be replaced you used to be able to send it in for reprograming, and a downgrade cus the chip isnt interchangeable, I wouldnt think there were any mods the the ECU other than that same program I would imagine,
      • BS87
        • 1606
        Still, most people who have the 021 upgrade to the 027, so i have no idea why you would want to do the reverse
        • elemental
          • Jan 2004
          • 112
          To get a remaped ECU for free
          • rs4pro3
            • 5808
            You can hand solder a chip into the 021 A couple of my friends with 325e did this one managed to fry the circuit board(not good with soldering) and the other worked fine. They were custom burned chips.
            85 325e 2.7 ITB'd stroker
