Sometimes when i go over bumps i feel a clunking in the front end. i can feel it in the steering wheel and it sounds like its coming from under the dash. is there something in the steering linkage that needs to be replaced? (i just bought the car and havent checked out anything yet)
steering linkage clunking?
Start by doing a full inspection of the car (control arms, CABs, tie rods, upper strut mounts, struts, wheel bearings, steering rack, motor/trans mounts, etc). You'll probably find worn parts that when replaced will fix the problemThe car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Its the CABs all day long. replacing the entire bottom control arm is recommended. It saves alot more time and kills 3 birds with one stone.sigpicComment
Sounds like the culprit. I'll check it out tonight. Everything else on the car is tight... maintained at the dealer its whole life (until now that is lol).Originally posted by Grueliusand i do not know what bugg brakes are.Comment
Is this a problem with non airbag cars? Glad you found the problem:)Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
