My car, quite possibly the most buggy and retarted amongst this server, decides its broken again.
I crank it, but it doesnt start. BUT! BUT! Randomly, 3 times now, I cranked it and it started for a second then died. Then just wouldnt start again. IT turns, the relays are good, the plugs are firing, the fuel pump in the gas tank works, I recon it does because when I took the hose off it was HIGHLY pressurized. But, probably in the 2nd pump, something happens. The fuel doesnt seem to stay compressed. It barely leaks out of the hose leading to the rail. Is it just definately that bad pump? Cause we replaced it, and uh, it just does the same thing.
*Also changed reference sensors, checked for the flywheel pin thing, all relays fresh, all grounds jiggled, detached, re attached (i think) and wiring harness pristene.*
Please help if ya can. If not, tell me to go bite one.
