Odometer and trip stopped working
  • dlmrun2002
    • Apr 2007
    • 808
    Just pulled cluster. Gears all look good. Speedometer still working. All other gauges working. Looked for "cold solders" on circuit board with magnifying glass. Didn't see any. AND--- I rotated the gears and they all seemd to work--odometer worked, etc... Could a gear been a little stuck or are we looking at an electrical problem? Any input is greatly appreciated..
    DLM
  • mattdk318i
    • Jun 2006
    • 3953
    Sounds electrical. I owned a 325is with the same problem. I just put up with it until i sold it. I should ask the New owner how he fixed it.
    • dlmrun2002
      • Apr 2007
      • 808
      Swapped speedometers--Same Prob
      Speedometers works.... not odometer or tripometer with a different speedometer. Bad circuit board? Possible faulty code plug? WTF..
      DLM
      • MattE30
        • 1520
        Is your clock working?
        97 Cosmos M3
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          I have the same problem, I could use some help too :)
          • MattE30
            • 1520
            I had this problem when I first bought my car when I was 16 (5 years ago). IIRC, everything on the cluster worked except for my odometer and mpg meter. I checked the fuse box, and one of them was blown. I replaced it, and everything worked. The clock and obc are connected to the same fuse as the odometer and the mpg meter, so thats why I asked if it worked or not.
            97 Cosmos M3
            • dlmrun2002
              • Apr 2007
              • 808
              CLock works... All gauges work.. minus odometer and tripometer....
              • e34john
                • Apr 2006
                • 3599
                have the same problem. I have to pull my gauge to look but i think something is loose because it was working fine until i went to reset the trip and now neither odometers work while everything else is perfect.
                • dlmrun2002
                  • Apr 2007
                  • 808
                  Well after swapping speedometers, I exercised the si board and control plug connections and odometer is working. Never actualy had to reset si board also. Lets see how long it holds.
                  DLM :)
                  • MattE30
                    • 1520
                    Yay!
                    97 Cosmos M3
                    • dlmrun2002
                      • Apr 2007
                      • 808
                      NICE M3 Matt.....
                      DLM :drink:
                      • e325i
                        • Jun 2007
                        • 61
                        I have a similar problem. My tach and odometer/trip aren't working, I just bought this car, what should my first steps be to try and fix it? I thought about just replacing it but I don't even know if that's the problem.
                        • dlmrun2002
                          • Apr 2007
                          • 808
                          tach not working is si batt symptom
                          Loosing tach and mpg gauge is related to bad batteries in si board. Plus the inability to reset service and oil lights is another sympton of bad si batteries. I'd look there first..Maybe try a reset..
                          DLM
                          • m_dudey
                            • 267
                            DLM :)
                            so I'm having the same issue. at first I had broken gears. I replaced all those, put everything back together and my odometer and tripmeter still doesn't work. everything else is working, speedometer, MPG gauge.
                            So dlmrun2002, how did you exactly exercise the SI board. and did you just swap the speedometer portion and nothing else? anybody have a picture of the SI board?
                            thanks
                            -Brian
                            • dlmrun2002
                              • Apr 2007
                              • 808
                              I just pulled it out and put it back in( re-seat connectors). Didn't swap speedo. Exercised control plug to( (re-seat again). HTH
                              DLM
