Should I change Diffs?
  • winstontj
    • Mar 2007
    • 500
    I have a 40% 4.10LSD now. When I redo the motor will I want something a little lower geared? It'll be some reasonably powered 2.7-2.8L variant eta cranked M20. I have the ability to use a 3.64LSD with a CR gearbox but somehow I think that would get me right back to where I am.
    What do you guys suggest to run for a rear end combo with a more powerful motor and a 5-speed OD box??
    Thanks!
  • drifty340i
    • Oct 2004
    • 1076
    dont do a 4.1 with a 2.7swap mate, go for a 3.64 or 3.73 and use the tq
    sigpic340hp V8 e30 FINISHED!!!!!
    Quick vid for ya ;) http://www.youtube.com/watch?v=vp5Eaf8xOgM
    NEW One on the track :)
    http://www.youtube.com/watch?v=K-AX5SzSLnk
    Cleaning up some 911s and Jap turbos
    http://www.youtube.com/watch?v=Ad79wsLdle4
    • PiercedE30
      • Apr 2005
      • 4220
      How much you want for the 4.10??????????????????
      My 2.9L Build!
      • winstontj
        • Mar 2007
        • 500
        its a 40% LSD rebuilt in 2001 so i probably will not sell it. It cost the PPO about $1,200 to get all the work done on it and I can't sell it for more than a few hundo so I'll let it collect dust till I get a track car in a few years.
        If I were to run a cr gearbox would the 3.25lsd be the best choice or should I look foe something taller? Is there a 3.10 or close?
        • FredK
          • 14763
          I think 3.25 will be fine if you have a 1:1 5th.
          I'd get a 3.46 if you want slightly more mechanical advantage. I have one and it's not that annoying at highway speeds.
          There is a 3.15 from a Z3 2.8; IIRC it is Torsen and not the traditional disc clutch type.
          • winstontj
            • Mar 2007
            • 500
            FredK are you running a 3.46 with a OD or CR gearbox? I'm not 100% sure if I want to run the CR box. The way I see it the only real reason there is to really run a CR box is mostly for bragging rights... which I may be after here.
            I'll look at a 3.46 or a 3.64 or if I do the CR maybe the 3.25. Do you think I could use the 3.46 for both? Would that be the most similar to the OD with a 4.10 or is there not really any interchangability between gearboxes with the same rear end #???
            • PiercedE30
              • Apr 2005
              • 4220
              I have a 3.46 LSD sitting next to my toolbox at work. I've got it pulled apart at the moment to R&R it and polish the gears.
              My 2.9L Build!
