Brute force
If you're not honestly worried about destroying your trunk lock (which sounds pretty much shot anyways) What you need is a powerdrill, a decent sized self tapping screw, and a crowbar. Drill the screw into the key slot but leave a bit sticking out for the crowbar. Put a block of wood down to pry against and pry that bitch out. It worked on my roommates motorcycle and I'm will to bet it'll work on your trunk.
R.I.P 07/01/09 - 04/23/10 :(
