well first off my car starts to shudder/shake when i step on the brakes, i just changed my CABs about 7-8 months ago and that had stopped my previous problem, but its back again, not as severe as pre-CAB change but still a pain in the ass, also it feels like my car wants to slide out more often when i take turns, if im going on and off/on ramp onto the highway i feel like the speed i could do it as is less then what it was a month ago, i feel like the car is swaying and the rear end wants to come out a lot sooner then before (i could be wrong here) and also when driving at high speeds it almost feels like the car is swaying back and forth, could it be the ball joints gone bad cause the new cabs caused a lot more stress, or something like tie rod ends.... thanks
car feels a little loose maybe?
Something that feels like a left/right movement at speed could be worn RTAB's and/or subframe bushings. Those could result in the rear of the car being a bit loose in turns.
A vibration in the steering wheel under braking could be uneven pad deposits on the rotors (likely if low-dust pads are being used), warped rotors, worn ball joints or tie rod ends, worn rack, worn shocks, or a combination of those. Throughly inspection the suspension and replace all worn parts and go from there.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
thanks for the info and yeah im probably gonna do the tie rods and ball joints, any suggestions on what make to get, should i do inner and outer tie rod or....1991 318is --- currently not road worthy
1991 318i ---- 308K - retired
so if you didnt get it like that did you glue fuzzy oil to the entire thing?Comment
anyone have an opinion on the AKG subframe bushings? i used there cabs and i love em.1991 318is --- currently not road worthy
when you buy tie rods it usually comes as one piece with both inner and outer already on the arm so its just a quick install at that point but make sure you get new boots(2) and clamps(4) and 2 lock washer to install the new tie rods on and also do a measurement of each old arm and adjust the new one to that length so it will be close to where is was before a new alignmentComment
