62111368299 $0.60 - 12 needed -- $7.20 red lines
63217167000 $2.00 - 2 needed -- $4.00 purple line
07119905358 $1.45 - 2 needed -- $2.90 orange line
(.60 x 13) + (2 x 2) + (1.45 x 2) = 14.10 ~ $15 dollars with tax for cluster repair
REAL TIME DEALER PRICE AS OF July 13th 2007
NOTES: the bulbs all twist out, the speedo and rpm, have the wedge type bulb that needs to be sit into the base. The purple line also have a base, just pull with pliers straight out from the black plastic between the connectors. Hope this helps some get the right bulb first. Oh and on real oem, there is a 2w bulb... that seem to go where the turn signal is, 1.2 w is just fine, mine is 1.2 there already. Please add any if anyone know of anything else.The rear fogs are not use unless you have them.
