running hot issues
  • ///M42 sport
    • 3952
    running hot issues
    my 318is is running hotter than normal. Usually when sitting in traffic the temp starts to creep up and I just turn on the heater. However I noticed recently that it doesn't really help anymore.
    Is this the fan clutch? How do I test this clutch.
    Also, I had to refill the coolant tank by about a liter after flushing it a month prior. I don't know if the coolant is just evaporating or leaking somewhere.
    Advise on things to check?
    Thanks.
    ________
    Bbw tube
  • Jordan
    • 12913
    To test the fan clutch reach out and insert a finger into the spinning fan. If the fan stops your fan clutch is toast. If it whacks your finger hard, and you wish you hadn't of done that... then the clutch is good :)
    https://mtechniqueabs.com/
    • e9nine
      • 1890
      Use a rolled newspaper to check the fan clutch (not your fingers ;) ) If it stops easily, you need a new fan clutch. Next after that would be a thermostat swap and then a water pump swap if all else fails. The fact that you're losing coolant is kinda scary, make sure no hoses are brittle and leaking ....
      Good luck.
      • Bitburger
        • Jan 2004
        • 147
        This might be a long shot but any chance that you've got air in the system from when you flushed it? Maybe you didn't it bleed completely or correctly? That will also cause you to run hot. Most likely though either fan clutch or thermostat as has been said above.
        • ///M42 sport
          • 3952
          When I bled it, I filled it to the top, capped it off, and turned the heater full blast. Is that how its done?
          ________
          NEW MEXICO MEDICAL MARIJUANA DISPENSARIES
          • Avus_325is
            • Mar 2004
            • 446
            Let the car run with the resevoir cap off to get all the air out of the system. It might take awhile so just let it run till the bubbles stop coming out. ;)
            • M-technik-3
              • 18946
              When was last time you changed the coolant? After you do that run some water wetter by Redline.
              • Bitburger
                • Jan 2004
                • 147
                Here's step-by-step directions on how to properly bleed a 318is cooling system: http://www.esatclear.ie/~bpurcell/31...nce.html#bleed
                Every 318is owner should know about BP's 318is site. It's saved my ass many a time. Hope that helps ya.
                • m42technic
                  • 1056
                  First off, check the ground screw for the coolant gauge on the back of the cluster. Ask me how I know this can cause problems... :roll:
                  James Peacock
                  WWFSMD?
                  • LowR3V'in
                    • 4209
                    This might be off topic, but if you take out the weather stripping by the hood and the underhood cover you'll notice better cooling.
                    Probably wont SOLVE the problem, but it'll help. :o
                    • Rob
                      • 8166
                      my m42 was running 'warm'. I swapped in a 75 degree thermostat, and flushed and bled the system, problem solved.
                      BEERTECH
                      • brodee
                        • Jan 2004
                        • 2914
                        75 degree or 175 degree??
                        "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                        1988 M3 - Track Rat
                        1989 325iC M50 Vert
                        1989 325i Coupe
                        1991 318is
                        1995 318ti Club Sport
                        2006 330i e90
                        2008 Tundra Crewmax
                        • Rob
                          • 8166
                          ETK called it 75 degree, but you're probably right, the actual temp would be 175
                          BEERTECH
                          • kencopperwheat
                            King of Kegstands
                            • 14396
                            Maybe 75 C?
                            Originally posted by Gruelius
                            • BavarianBimmer
                              • 951
                              ETK works with Celsius (atleast here in Europe)
                              1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                              1997 E36 328iT
                              1990 E30 325iT 24v SOLD
                              1989 E30 325i 2.7i M-Technic II SOLD
